Internet mobilny - pytanie co wybrać oraz pytanie o Aster...
  • lu1227
    • 31
    Pierwszy to przeladowanie turbiny raczej nie ma nic wspolnego o ile cos z rozpadnietej turbiny nie wlecialo do cylindrow.
    18080 Coolant Fan Control 1: Open or Short to Ground
    There is a whole list of testing procedures but you need a DRBII scan tool to do the tests. SYMPTOM P1762-GOVERNOR PRESSURE SENSOR OFFSET VOLTS TOO LOW OR HIGH WHEN MONITORED Continuously with the key ON and the engine running. SET CONDITION This code will set if the governor pressure is out of range in park or neutral for 1.3 seconds for three consecutive bad 3.0 second tests and sump temperature > 10 �C (50 �F) and < 127 �C (260 �F) are required to set the code. POSSIBLE CAUSES Powertrain control module Powertrain control module - 5 volt supply high Powertrain control module - after 5 volt supply shorted to voltage Powertrain control module - after 5 volt supply shorted to voltage in trans Repair the 5 volt supply circuit and check the PCM Replace the trans solenoid assembly and check the PCM Intermittent condition Powertrain control module - internal fault 5 volt supply circuit open Check for other trans DTC's Governor pressure sensor signal circuit shorted to voltage inside trans Check trans fluid level and condition Governor pressure sensor signal circuit shorted to voltage Park neutral DTC present 5 volt supply circuit shorted to ground Governor pressure sensor signal circuit shorted to 5 volt supply circuit Governor pressure sensor signal circuit shorted to 5 volt supply circuit inside trans Governor pressure sensor signal circuit shorted to ground 5 volt supply circuit shorted to sensor ground Governor pressure sensor signal circuit open inside trans Governor pressure sensor signal circuit shorted to sensor ground GOV pressure sensor signal circuit open Governor pressure solenoid Governor pressure sensor signal circuit shorted to ground inside trans Powertrain control module - 5 volt supply circuit low Sensor ground circuit open Transmission line pressure low Governor pressure sensor signal circuit shorted to sensor ground inside trans 5 volt supply circuit open inside trans 5 volt supply circuit shorted to ground inside trans 5 volt supply circuit shorted to sensor ground inside trans Sensor ground circuit open inside trans Governor pressure sensor Copyright � 2002 ALLDATA LLC That means you go to your local Dodge dealer, grab the Governor Pressure Solenoid, Transducer, 2 gallons of Mopar ATF, a filter, and gasket and change them out. It takes about 1 hour total to do the job in your driveway. YOU DO NOT HAVE TO REMOVE THE VALVE BODY Once the pan is dropped and the filter is removed you will notice the wiring laced threw-out the valve body. These lead to your GPS and Transducer solenoid. I didn't want to go the dealer route and pay big bucks for the Governor Pressure sensor and Governor Pressure solenoid. With a little online searching I found Transtar Industries, Inc. at www.transtarindustries.com Part numbers where 20A-120A for the sensor and 5A-303 for the solenoid. The prices quoted me were just over $120 for both parts. This was $100s better than what the dealer quoted me. This was for a 1997 46RE transmission. Also applies to the 47RE trans. MRinfinit3 Jake- ASE Master Certified Tech. 2008
    Cos takiego znalazlem, to moze miec cos wspolnego z uruchomieniem silnika.
    Jakbys szukal specjalisty to mozesz udac sie smialo tu: http://lubelskie.teleadreson.pl/lubl...81411aad0.html
  • Hunter
    • 1655
    Szanowni Forumowicze - jak w temacie. Chciałbym w najbliższym czasie zmienić operatora netu i w związku z tym rozglądam się za czymś interesującym. Najlepiej gdyby to był net bez abonamentu, a na zasadzie pre-paid. Ponadto modem bardziej uniwersalny czyli na USB (w grę wchodzi laptop i PC'et). Transfery miesięczne w okolicach 3-5 GB. Wpadła mi w oko oferta Play, więc gdyby ktoś miał jakieś informacje z własnego doświadczenia odnośnie usługi u tego operatora to proszę o kilka słów. A i oczywiście cena też w jakiś sposób będzie miała wpływ na mój wybór Jak na takim necie chodzi Skype czy inne komunikatory głosowe??
    Ponadto drugie pytanie dotyczy firmy Aster. Wziąłem rok temu net u nich. Wszystko spoko do czasu stycznia tego roku. Pod koniec stycznia (chyba coś około 28) dostałem w kopercie 3 faktury. Na pierwszej kwota jaką normalnie płacę, na drugiej tak samo, a na trzeciej na marzec o 40 pln więcej??? Spoko - tel do biura obsługi klienta i ciekawostka. Pytam o co chodzi, a Pani do mnie, że kończy się Panu umowa i została automatycznie przedłużona. (???) Spoko... Więc mówię, że chciałbym wymówić. A Pani - musi Pan to zrobić 45 dni przed końcem umowy. (???) Spoko2... Mówię, O.K. Tylko czemu nie dostałem żadnego pisma w tej sprawie? A Pani - w umowie jest ta informacja, a my nic takiego nie wysyłamy. I po temacie. Teraz muszę zapłacić marcową fv (140 pln), nawet gdybym rozwiązał umowę (bo jest 45 dni). Jedno mnie tylko zastanawia... Skoro faktury w ostatnich dniach stycznia, to jak do jasnej cholery miałem zrobić sobie 45 dni na wypowiedzenie (do marca), kiedy zobaczyłem wyższą kwotę na fv i nie chcę się zgodzić na te nowe warunki??? Co ciekawe... na kopercie nie ma żadnego stempla z datą kiedy wysłano, a na fv ze stycznia widnieje data 7 styczeń 2009, więc jak tu cokolwiek można wyegzekwować???
    Z góry wielkie dzięki za info
    Arek 'Hunter'
    • szkoda
      • 22543
      Zamieszczone przez Hunter
      nie dostaniesz żadnego pisma, bo podpisałeś umowę rok temu i jest to tam wyraźnie napisane, ja też zazwyczaj nie czytam takich umów zbyt dokładnie , ale akurat tutaj mają rację IMO.
      i nie mają tu nic do rzeczy daty wysłania tych faktur, miałeś wypowiedzieć na miesiąc czy tam 45 dni przed końcem umowy i tyle.
      saport techniczny baj DGW
        Tak umowy przedluzaja sie automatycznie, a okres wypowiedzenia jest wlasnie dosc dziwny. To taki haczyk w wiekszosci tego typu omow ostatnio.
        Mam Playa i dziala mi to roznie. Czasem chodzi znosnie, ze neta mozna przegladac bez problemu, a czasem ma takiego mula, ze lepiej nie mowic. Nie mam porownania z innymi ofertami tego typu, wiec nie wiem.
        Zastanowilbym sie nad blue connect z Ery.
        Taka ciekawostka, jak nie masz modemu, a chcesz zestaw pre-paid to kup zestaw startowy za 129zl w Play online, sciagnij simlocka, za darmo wskazowki sa po calym necie, a nastepnie mozesz juz uzywac kazdej karty
        • palioza
          • 417
          Ja mam blueconnecta i generalnie jest tak:
          jezeli jestem w zasiegu hsdpa czy tez umtsa to zapiernicza az milo. Pingi po okolo 100ms, wiec da sie przezyc (coprawda pograc nie, ale to mnie ryro). Jezeli jestem na edge albo gprsie to kapa totalna, internet praktycznie nieuzywalny.
          Wobec czego jezeli planujesz uzywanie netu glownie w jakimstam miejscu to sprawdz zasieg. NIE kieruj sie mapkami na stronach operatora bo czasami jest gorze, a czasami lepiej niz pisza. Najlepiej wez kogos z telefonem/modemem i sprawdz jak w okolicy to chodzi.
          Audi A7 3.0 TDI 313KM/653NM mocy dostarcza http://www.dynosoft.pl/ ;-)
          • kowal 2002
            • 5161
            Ja też używam erowego Blueconnect-a tyle, że jako neta stacjonarnego. Mam w domu TAKI router, z włożoną kartą GTmax HSUPA i podpiętą na stałe TAKĄ UMTS-ową anteną. Net śmiga aż miło, transfer ( download ) utrzymuje się w okolicach 1800 kbps ( czyli ok. 225 KB/s ).
            Jak ktoś nie ma dostępu do stałego łącza to jest to super wygodne rozwiązanie "dla domu", ale niestety jeśli ma to być net bardziej "mobilny" niż domowy to lepiej używać bezpośrednio podpiętego modemu USB ( ten erowy ICON USB jest naprawdę niezły, szczególnie jeśli chodzi o antenę/zasięg ).
            • Salt
              • 178
              Co do mobilnego dostępu to ja bym zaczął od odpowiedzi na pytanie gdzie go chcesz używać. W jednym miejscu przez większość czasu i myślisz o nim ze względu na ograniczoną w tym rejonie dostępność operatorów 'stacjonarnych' czy rzeczywiście chcesz się z nim mocno przemieszczać? W zależności od tego która opcja ma u Ciebie większe znaczenie wybrałbym to co daje Ci najszybzy dostęp w miejscu gdzie korzystasz najwięcej, albo to co daje Ci najlepsze pokrycie przy przemieszczaniu się.
              A Aster niezależnie od czytania umów to firma stosująca zakazane praktyki i zapisy w umowach. Dostali za to prawie dwumilionową karę, zmienili regulamin i chyba jeszcze w związku z tą zmianą można ich umowę zerwać bez konsekwencji.
              Zerknij tu:
              Szczegółów nie znam bo mam u nich samą kablówkę utrzymywaną tylko dlatego że na platformie N nie ma kanału kuchnia.tv:-)
              andrzejwojnar.pl
              alchemiaswiatla.blogspot.com
              • b707
                • 1272
                Co do Aster
                Przedłuzli Ci umowe ale chyba na czas nieokreslony. Dlatego stawka za miesiąc jest większa.
                Jezeli chcesz dlaej korystac z ich usług to zapytaj czy nie maja dla Ciebie nowej oferty. W UPC to działa i mozna bezproblemu przedłużac umowe na kolejne okresy [rok lub pół] na identycznych lub lepszych warunkach.
                pzdr
                Adam
                • szkoda
                  • 22543
                  co do mobilnego -> przede wszystkim na twoim miejscu wziąłbym od kogoś na próbę na 2-3 dni, żeby się upewnić, czy uzyskujesz u siebie najwyższą prędkość :idea:
                  • Lashlo
                    • 1455
                    I na bank nie bierz Orange-to kompletnie nie dziala!!
                    • QBA
                      • 2646
                      Pre paid to raczej malo oplacalna forma
                      Ja obecnie korzystam z Play. Stosunek jakosc/cena IMO najlepszy. Ale... tak jak pisze Microft, czasami zamula niemilosiernie :roll: No i minus taki, ze dziala to tylko w UMTS/HSDPA, czyli jak wyjedziesz na jaki pipidowek, to niestety nie skorzystasz z neta jezeli nie bedzie zasiegu w/w sieci :? Ale w Warszawie i powiedzmy w promieniu 20km od, nie odnotowalem jakis problemow
                      Wczesniej przez jakies pol roku urzytkowalem pozyczonego BC z Ery (limit 5 czy 4 GB). Tez dzialalo to calkiem spoko, tylko cena jak dla mnie z kosmosu :lol: W zyciu bym osobiscie tego nie wzial I np. w takiej Falenicy dziala tylko w GPRS, a to przeciez blisko Centrum W-wy :roll: U mnie w Kobylce smiga z full predkoscia No ale ja mam nadajnik jakies 300m od bloku
                        QBA, Ogolnie pre-paid nie wychodzi za dobrze, ale jak w dobrej cenie dostajesz 60GB na rok to nie ma co narzekac. Do zwyklego neta, poczty, skype, gg wystarczy. Jak trzeba cos sciagnac wiekszego, to mam inne zrodla neta ciut szybsze
                        Jak to liczylem to za ostatni miesiac wykorzystalem jakies 3GB ogolnie transferu. Jest to do przezycia.
                        Co do BC to chyba juz nie maja tak cienkiej oferty jak kiedys.
                        • QBA
                          • 2646
                          Microft Ja mam abonametn w Pay i 5GB ledwo mi starcza, przy normalnym uzytkowaniu. Ale cena 45zl miesiecznie jest calkowicie akceptowalna. Niby jest limit predkosci 1Mbps, ale tak na prawde to i predkosc UMTS bylalby calkowicie wystarczalna do takich rzeczy jak Ty piszesz
                          BC z 5GB, to juz abonament 99zl, takze jak dla mnie nie do zaakceptowania I do tego nawet w samej warszawie potrafi mniec jazdy z zasiegiem :roll: Przynajmniej z mojego doswiadczenia.
                          Hunter, przy tym co piszesz, ze transfer 3-5GB miesiecznie, to IMO Play w Wawie najkorzystniej wychodzi.
                          Pre-paid z tego co sie orientuje, to wszedzie podobnie, czyli 30gr za 1MB, czyli czy 3GB wychodzi 300zl :diabelski_usmiech A na zadne promocje nie trafilem :roll:
                          Aa i w tej drugiej miejscowosci, co masz w profilu, to czesto przebywasz :?: Bo tam Play, to juz moze miec problemy z zasiegiem :roll:
                          • szkoda
                            • 22543
                            Zamieszczone przez QBA
                            to mi starczało średnio na 2 tygodnie :roll:
                            z mojego też...
                            • QBA
                              • 2646
                              Zamieszczone przez szkoda
                              No mi to starcza ale tylko do maili, przegladanie for i komunikator, thats all Ale czesciej konczy mi sie po 3 tygodniach
                              Do sciagania, to u babci Aster 10 Mega zalozylem :diabelski_usmiech
                              • Hunter
                                • 1655
                                dzięki Panowie za info... Faktycznie różnie z tym ściąganiem bywa, no i jeszcze nie wiem jak zachowywały by się na tym pre-paidzie połączenia VPN czy przez VNC, które są też mi niezbędne do życia... Choć na BC dają radę.
                                Maicroft, właśnie myślałem o tym zestawie za 129 pln, albo tym z 60 GB na rok.
                                szkoda, chciałem tak zrobić, żeby pożyczyć i przetestować co i jak.
                                b707, spróbuję sprawdzić Twoja radę... Może akurat zmiękną i zaoferują lepsze warunki i się problem rozwiąże....
                                QBA, tak bywam i w tej drugiej miejscowości, ale raczej tak na weekend...
                                Lashlo, właśnie kumpel mi też Orange odradzał, bo strasznie to wolno działa...
                                Salt, dzięki za linki... Nie wiedziałem, że tak polecieli sobie w kulki z ludźmi - kolejki jak za komuny
                                kowal 2002, a jak z opłatami sprawa wygląda?? Kwoty rzędu jakich wielkości??
                                palioza, na mapki operatorów zawsze patrzę z przymrużeniem oka
                                • QBA
                                  • 2646
                                  Hunter, w Play'u przeciez jest tak, ze do 7 dni od zakupu mozesz bez problemu oddac Takze bierz, testuj i jak nie podpasuje to oddajesz
                                  • b707
                                    • 1272
                                    W niektórych placówkach Aster i innych to std w Wawie... Emeryci chca zaoszcedzic kilka złotych na przelewie :twisted:
                                    Adam
                                    • szkoda
                                      • 22543
                                      ja UPC zapodałem kilka dni temu, na razie jestem w szoku :lol:
